boost
Old May 19, 2007 | 07:21 PM
89blackonblack's Avatar
89blackonblack
Default boost
i know i should be in the boost section but no one is ever in there and i want an opinion.. i have the 302 gt40 ford racing crate engine with 70mm throttle body 24lb injectors trick flow street intake 70mm mass air 255 fuel pump 3:73's... i drive the car everyday but want to add boost to it.. no spray.. but i want to it to last so i was thinking abou just going with like a 5 lb kit from vortech... anyone know what kind of hp gains i may get or know anyone that runs a 5lb kit
Old May 19, 2007 | 08:05 PM
89blackonblack
Default RE: boost
anyone with any ideas? suggestions?
Old May 19, 2007 | 09:42 PM
luckythirteen13's Avatar
luckythirteen13
Default RE: boost
5psi will get you 60-70hp. for such a small gain it seems like a waste of money to buy a sc. if your going to buy a sc, take advantage of it. my old motor made 280rwhp n/a and 461rwhp with the sc and meth injection.
Old May 19, 2007 | 09:45 PM
bfuller's Avatar
bfuller
Default RE: boost
ORIGINAL: luckythirteen13
was it a daily driver or not?
Old May 19, 2007 | 09:47 PM
93 LX FiveO's Avatar
93 LX FiveO
Default RE: boost
his motor makes 345hp at the crank.. i would say easily 300 to the wheels
for his daily driver 5lbs boost is perfect. the vortech kits allow u to upgrade any system too so dont worry about down the road plans.
u will see over 400hp at the crank easily
well worth the $$$ IMO
ive been planning the same thing just need to make my motor worthy first
Old May 19, 2007 | 09:48 PM
luckythirteen13
Default RE: boost
yes it was. its the only car i have so i have to drive it from A to B. my budy is trying to convince me to sell the motor in my sig that we just built about 1000miles ago and to build a 331 in a boss block. if i decide to go for it, we will be shooting for a 600rwhp daily driver.
the motor in my sig is making an estimated 500rwhp just because the sc cant keep up with the volume demands of the motor. i havent dynoed it because i have an ems and i tuned it myself on the street. its my daily driver motor
Old May 19, 2007 | 09:55 PM
89blackonblack
Default RE: boost
my motor only has about 1000 miles on it right now and i know i can upgrade th 5lb system when iget bored with it but i think for now it would some more power and a little more fun... i just want the motor to last and i am afraid if i run 8 or 9 lbs it would be too much for something i put atleast 300 miles a week on... if its not raining
Old May 19, 2007 | 10:02 PM
cassidymustang's Avatar
cassidymustang
Default RE: boost
its fun having the s/c. even with 6psi you will feel a big difference. and going from 6 psi to 9 psi on a daily driver shouldnt be that big of deal
Old May 19, 2007 | 10:03 PM
89blackonblack
Default RE: boost
luckythirteen what was your setup on your old motor? na and how much boost? and how much did the meth injection add?
Old May 19, 2007 | 10:16 PM
luckythirteen13
Default RE: boost
ORIGINAL: 89blackonblack
stock block with all the stock internals including cam. afr heads, typhoon intake 10psi of boost and all the supporting mods. the meth adds about 50rwhp. here is a vid http://youtube.com/watch?v=HE2m6Wmh2xw
