Speedo Correction?
Old May 21, 2007 | 07:24 PM
medium_jay's Avatar
medium_jay
Default Speedo Correction?
Hey. I just put some Ford Racing 3.73's in my stock 8.8 inch rear end about a month ago. I knew my speedo would be off and it is by about 30%. (When my speed says 100 Km's/H its really 70 Km's/H) I went to a few local shops and I'm pretty sure the parts only 40 bucks or so Canadian from Ford. I know there's obviously cheaper places to get this part so if you guys could maybe give me a link or something of that sort to find out where I could get this and more importantly how dificult it is to install? Thanks. (1990 Ford Mustang 5.0 LX, Standerd T5 Transmission)
Old May 21, 2007 | 07:28 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: Speedo Correction?
ORIGINAL: medium_jay
sadly your only option is to remove the tailshaft housing from the transmission, and change out the drive gear on the output shaft along with the driven gear on the speed sensor.
There are no combinations of the 8t drive that will accurately correct for the 3.73's. you need to go with either a 7t or 6t drive gear
Old May 21, 2007 | 07:39 PM
medium_jay's Avatar
medium_jay
Tabronack... thanks anyways
Old May 21, 2007 | 07:53 PM
AdderMk2's Avatar
AdderMk2
Banned
Its actually not as bad a job as many people think it is. There are 8-10 bolts holding the tailshaft housing onto the trans case. you must remove the shifter, punch out a roll pin, unbolt the driveshaft, drain the tranny fluid, unbolt the tranny crossmember, lower the back end of the trans down, support the tranny and unbolt the tailshaft housing... then it slides right off.. there is a clip holding the gear in place, slide the whole thing off, and install a new gear...
clean the tranny, apply some RTV silicone, and slap it all back together
Old May 21, 2007 | 08:46 PM
marx91's Avatar
marx91
i just had my trans rebuilt, and i got a 7t drive gear put in and along w/ the 23t speedo gear i already had
my speedometer is pretty much right on w/ 3.73's,heres the part # for the 7t drive gear... E3ZZ-17285-A
Old May 21, 2007 | 08:49 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: marx91
Actually, your speedo is still off. You should be running the 21 tooth.
[IMG]local://upfiles/26017/23AC3750DD44451DBC65E93E75DA774E.jpg[/IMG]
Old May 21, 2007 | 09:41 PM
black89gt's Avatar
black89gt
hey adder.. up to an 89 has the 7th tooth drive gear right? And anything later than taht will be 8 tooth?
Old May 21, 2007 | 10:26 PM
AdderMk2's Avatar
AdderMk2
Banned
ORIGINAL: black89gt
yes. 90-95 was 8t.... which sucks for me...
good thing I know how to take out the drive gear.. hehe
mtgldr
Feb 3, 2024 09:00 PM
UrS4
Oct 3, 2015 06:23 AM
69Volunteer
Sep 30, 2015 10:39 AM
ccdguy
Sep 19, 2015 05:20 PM
PNYXPRESS
Sep 14, 2015 09:50 PM
