problem
Old May 22, 2007 | 12:07 AM
militarymustang88gt's Avatar
militarymustang88gt
Default problem
latly i have been driving around my temps stay right at around 160-165 and i stop and water is gushing out of my overflow tank fill it up everymorning and check it in the afternoon and when i take the cap of even when really cold it sounds like a crap load of air rushing out like when it is hot but it would be after not driving for 8-9 hours what could be causing this?
Old May 22, 2007 | 12:11 AM
PX429's Avatar
PX429
Default RE: problem
So let me get this strait. Your car is not everheating but you are losing coolant?
Is it only your overflow tank that is losingcoolant or does your radiator lose coolant also?
mattdel's Avatar
mattdel
Default RE: problem
how many people on this forum have bad headgaskets? geez
Old May 22, 2007 | 12:12 AM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: problem
sounds like a bad cap and or the wrong water pump
militarymustang88gt
Default RE: problem
it goes from the radiator into the resivior and then pours out and none gets sucked back in but there is an *** load of air that comes out in the morning when i go to fill it up
Old May 22, 2007 | 12:24 AM
PX429's Avatar
PX429
Default RE: problem
ORIGINAL: militarymustang88gt
Start with the little stuff. First off, why are you running a 165 Thermostat? Second get a new cap. And cross your fingers that Mattdel is wrong.
Old May 22, 2007 | 12:26 AM
militarymustang88gt
Default RE: problem
well it is the waterpump that is was allways in thier the cap was new as of a month ago and its a 160 thermostat
Old May 22, 2007 | 12:27 AM
mattdel's Avatar
mattdel
Default RE: problem
first and foremost, ditch that thermo. your not doing the motor any good running it that cold. i dont care what your buddys tell you. the colder thermostat trick DOES NOT work for EFI.
Old May 22, 2007 | 12:29 AM
militarymustang88gt
Default RE: problem
it was in thier too i have my 351 about halfway done so i aint gonna waste money to change a part out i didnt pay for but i was wondering how air was getting presureised in system and causing the coolant to run out the resivoir
Old May 22, 2007 | 12:36 AM
mattdel's Avatar
mattdel
Default RE: problem
think about it logically, if air is entering into a supposedly sealed system, obviously you have a suction leak.
