Clutch Quadrant
I am going to be replacing my clutch Quadrant, installing a new clutch cable, and a firewall adjuster. This is my first time with this, and I have found the following link to us as directions. (Click on the Number 6 option to get to the install section)
http://www.thompsontransmission.com/...ster%20install
Is this correct?
Do you have any additional tips that would help?
Any comment at all really.
Thanks in advance guys.
Is this correct?
looks pretty detailed....i used a pick set to get the cotter pins out of the rod....made it a little easier...
also i didn't remove the seat...it was a little more difficult, but worth not pulling the seat...
taking the old quadrant off and putting the new quadrant on, have the clutch pedal pushed down as far as possible, move the carpet out from behind it if you have to, if its down far enough the quadrant will slip right on no problem. when you get in there youll see what i mean, cause youll stare at it and say how the hell am i supposed to fit these things in and out of here!
junior04
Sep 28, 2015 10:53 AM
ccdguy
Sep 19, 2015 05:20 PM
