cam and heads suggestions
here in a few weeks im going to be pulling the motor. im not boreing it out at all. im just going to up the comp to about 9:1 or so. my questions are what are some good cam and head combos? id like a cam that has a decent lope. nothing to insane but something fun. the car is a DD . Im only wanting to push about 350-400hp. thanks guys
RE: cam and heads suggestions
ive got an 89 gt with a 5 speed. i thought the 5.0s had 8.5:1. what do you all suggest for the comp inc? after i do the motor im going to throw some 3.73 in along with some 17x9. car is basically stock besides exhaust.
go with some trick flow heads and a xtreme energy cam by comp cams.224 232 duration at .050,
.555 .565 , l.s.a 112. with a cobra u/l intake and notched pistons and you will be moving
You gotta have AFR heads, don't think trick flow will get you there, maybe close. I would recommened doing a stroker 331 or 347 with AFR 185 heads, then your on you way
i hadnt made up my mind about intake yet. ill most likely do afr heads. i was hoping not to bore it. just uping the compression. a few years back i help my dad build a vette and it made 400hpat the wheels off just motor but it had a wicked cam in it. i was hoping to build a motor that wasnt quite as radical. if it comes down to it i can deal with a lopey cam. i at least want something with some pop. what do you all think?
