'84 H pipe on a '87
'84 H pipe on a '87
Will a H pipe with 4 cat's off a '84,work properly on a '87 with speed density?
I have a real nice used one, and I'm moving to Tn. and I may have to have the cat's on to pass there (I don't know if they'll even check).But once I put it on, I'm going to leave it on, as long as it works right. I have never had the stock exhaust on it, and I never checked into it before, other then I know it came with only 2 cat's originally, and 2 O.S.
Pat
Pat
RE: '84 H pipe on a '87
ORIGINAL: HemiTCoupe
Will a H pipe with 4 cat's off a '84, work properly on a '87 with speed density?
I have a real nice used one, and I'm moving to Tn. and I may have to have the cat's on to pass there (I don't know if they'll even check). But once I put it on, I'm going to leave it on, as long as it works right. I have never had the stock exhaust on it, and I never checked into it before, other then I know it came with only 2 cat's originally, and 2 O.S.
Pat
Pat
that pipe will work its not stock for 84 they had a y pipe that year and yes he is right you should have 4 cats as well stock. do you have cats on your car now? if you have just the two you will be fine to pass inspection dont even worry about swapping the pipes out
Thanks,
I do not have cat's now, and I don't know what theyhookedthe EGR valve to?
The one I havethatcame off the '84 has4 small cat's, and the tube for the EGR ispinched shut at the end.
What can I usefor tubinghook to the EGR?
Pat
Pat
thats not the egr thats for the smog pump. the smog pump will have a hose that comes out the back the splits into two one hose goes to the back of both heads the other hose goes to the tube in the exhaust dont even worry about it just get it welded shut i passed emissions with the hose blocked off and no smog pump at all
ORIGINAL: HACKGT350
I don't know how Tennessee does their inspections, but in VA (I am assuming it would be similar) if you go to the right place they don't look under the car. When I get my inspection then check the light, horn, and that is about it. I would wait until I got there and ask arond, or try to find someone who knows where to go.
ORIGINAL: HACKGT350
I will not buy from a pic, and their word again! I will always go and look for myself first!
Thanks for the info guys!
Pat
09-24-2015 09:18 PM
trashxtrash
09-20-2015 10:49 PM
