Simple Green?
Old May 25, 2007 | 09:02 PM
fasfwd's Avatar
fasfwd
Default RE: Simple Green?
cover the distributor, coil, and airbox....and u should be ok, if u have a air compressor then spray off the electroical stuff after cleaning....for best results start car up for about a min (do not let it get up to temp) just get the motor a little bit warm (so all the dirt and grease etc will come off easier) and shut it off, spary ur cleaner on, rinse, and whenever ur done cleaning, start the motor up with the hood up and let the heat from the engine dry it. im tellin i would use the black magic engine cleaner its the best for the buck and wont fade any rubber components
Old May 25, 2007 | 09:08 PM
5.0LitreSN95's Avatar
5.0LitreSN95
I'm still having a little trouble locating the coil, you say its on the engine, mind if I ask where exactly, be specific and use small words please,I'm a little stupid today
Old May 25, 2007 | 09:55 PM
blackout's Avatar
blackout
ORIGINAL: 5.0LitreSN95
Follow the plugs from the distributer to where they end and cover those up up as well as the big distributer that says MSD on it.
Just stick a sealed bag over your intake filter and tape it so water cannot get in.
jwog666
Dec 27, 2021 08:09 PM
Thunderball
15
Nov 22, 2015 11:49 PM
flash_xx
Oct 16, 2015 07:23 AM
nmra1965
Other Professional Racing
Sep 26, 2015 10:46 AM
