Emissions questions
Emissions questions
How much of the plumbing from the air/smog pump back do you need to pass the sniffer?
I was wondering if I could connect a hose from the air/smog pump directly to the mid pipe without all the actuators and valves that Ford used originally.
Any reason why this would not work???
I checked and found out that many of the components are not available.
Or should I just go to Crazy Rays (junk yard) and cobble together the original plumbing setup.
RE: Emissions questions
So just put the cats on with the O2s and see what happens...? Right now I am getting code 41 and 91 (Missing O2s).
Partsare on the way
I missed the Fed Ex guy and he won't be back til Tuesday.[:@]
By the way Adder...your little 'starter saver' trick works as stated.
One of these days I am going to post pictures of this project...maybe after paint.
Thanks
Partsare on the way
Thanks
ORIGINAL: AdderMk2
with a good set of cat's you dont need the air pump... if your car was running right, youd be all set
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
