Is this MAF too big for my new setup?
I am going with tf track heat heads (some porting and polishing), stg.1 trick flow cam, trick flow track heat intake, 70mm tb, 24 lb injectors, 255 lb fuel pump, full msd ignition with the AL box. I was going to buy an 80mm MAF off of e-bay that is calibrated for 24 lb. injectors. All that i know i should be looking for is something that is bigger than my throttle body. Could someone please educate me on what i should be looking for? Will this maf be ok? Thanks
RE: Is this MAF too big for my new setup?
An aftermarket MAF is calibrated to the injector AND the ecu. Make sure that the MAF is cal'd for you ecu as well...
If the MAF is a PMAS/ProM you should be fine.
I suggest passing on the C&L's.
If you are willing to get a new custom tune when you install the new MAF, then there are other options as well.
jason
jason
I was under the impression that i NEEDED a new MAF that was calibrated to 24# injectors. I have to get a tune after doing my h/c/i anyways so do i not need a new MAF?
you NEED to get a tune to run 24# injectors... you can still run the stock maf, but youve gotta get it tuned first
Your tuner can set the chip to adjust for the 24# injectors, then you can install it and bring him the car.... many people do not think of this
ORIGINAL: AdderMk2
ORIGINAL: drhoward
It shouldn't hurt anything to go larger though
