Leaking Oil
Old May 28, 2007 | 01:32 PM
blackout's Avatar
blackout
Default Leaking Oil
I just picked up my 92 5.0 and it leaks oil about 30 drops a night.
I haven't gone under and checked it out yet, but should I just buy a new gasket, do you think that will fix the problem? I mean i'm sure it's not coming from the drain plug so worst comes to worst a new oil pan and gasket to fix the problem i'm hoping.
Let me know what you guys think and have done.
Old May 28, 2007 | 01:34 PM
mattdel's Avatar
mattdel
Default RE: Leaking Oil
oil can leak from any gasket on the motor, pretty much. your not doing yourself any favors by guessing its the oil pan, when you could have a bad rear main, or valve covers, etc...
plus oil pans dont generally leak when sitting. the oil is well below the gasket when its sitting still.
take a look. start at the highest point and work down.
Old May 28, 2007 | 01:51 PM
86 5.0L's Avatar
86 5.0L
rear main seal is what I always see going bad....
Old May 28, 2007 | 02:22 PM
luckythirteen13's Avatar
luckythirteen13
before asking for help, figure out where the leak is.
Old May 28, 2007 | 03:29 PM
Blckstng93's Avatar
Blckstng93
Probably the rear main. After 140k mine is beginning to leak a bit. Lots of grime between the pan and the bell with not much on the pan itself.
If the underside is covered in oil and grime clean up whatever oil you find and put a piece of cardboard under there, Check it every now and again and you have your leak.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
