removing trans from motor?
i feel like an idiot askin this, but i just pulled my motor and trans a few mins ago, removed all the bolts from the bellhousing...i cant get my trans to come of my motor... i looked to see if there were any bolts that had to be removed from the flywheel, but there isnt ANY! what needs to be done in order to get the trans off?
RE: removing trans from motor?
i picked up on the motor and trans with my enigine puller and with all bolts out, i grabbed the backend of the trans and kinda rocked it back and forth... everything tht would keep it from coming out seems to be removed, i just dont wanna shake on it to much and hurt somthin ya know.
yea i took the starter out and spun the flywheel around to see if there was any bolts in it cause usually when u remove trans from a motor 9 out of 10 times u gotta un-bolt the flywheel...but i seen where there was no flywheel bolts so ive tried to wiggle the trans out but its not comin. ive just kinda not been to rough with it cause i dont wanna screw anything up as far as scarring somthin.
ORIGINAL: fasfwd
well if its a manual... why the hell havent you just taken out the four 15mm bolts that hold the tranny to the bellhousing???
and why the **** would you look for torque converter bolts if its a manual...
ORIGINAL: AdderMk2
