pistons
Old May 28, 2007 | 05:48 PM
F5GTS331's Avatar
F5GTS331
Default pistons
having trouble getting my snap rings in my pistons. they are keith black full floating pistons that came with my scat stroker kit. ok i can get the one side clip in then i cant get the other side to clip in all the way. any ideas?
Old May 28, 2007 | 05:51 PM
mattdel's Avatar
mattdel
Default RE: pistons
sounds to me like you are in way over your head... those are compression and oil rings, you need a piston ring compressor on them, and then slightly beat the piston into the cylinder.
Old May 28, 2007 | 05:56 PM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
i know what oil and compression rings are. let me say this again. these are full floating pistons which have clips at each end of the wrist pins and the lock rings arewhat i amhaving trouble gettin in.
Old May 28, 2007 | 06:00 PM
mattdel's Avatar
mattdel
Default RE: pistons
With the wrist pin installed, using a new wrist pin clip and installation tool or screwdriver carefully install the clip into the wrist pin clip retaining groove so that the opening in the clip is facing towards bottom of the piston.
Old May 28, 2007 | 06:01 PM
FuzzyDiceRule's Avatar
FuzzyDiceRule
Default RE: pistons
i dont think hes at that part yet matt, i think he means he cant get the actual rings seated in the piston
Old May 28, 2007 | 07:43 PM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
naw he's at the right part. im not puttin the pistons in the block im just puttin the pistons on the rods, and can only get one clip to go in the groove all the way. so, matt the opening of the clip has to be facing down?
Old May 28, 2007 | 07:50 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: pistons
ORIGINAL: FuzzyDiceRule
your reading comprehension sucks
my77stang's Avatar
my77stang
Default RE: pistons
yeah opening of the clip faces down, but that shouldnt have anything to do with the fact that you cant get the clip in[&:]
Old May 28, 2007 | 07:53 PM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
ORIGINAL: AdderMk2
i see what he means now take it easy onme k?
Old May 28, 2007 | 07:55 PM
AdderMk2's Avatar
AdderMk2
Banned
Default RE: pistons
ORIGINAL: skinny_man18
ORIGINAL: AdderMk2
I wasnt taslking to you...
BTW, are you using snap ring pliers?
