pistons
Old May 28, 2007 | 07:56 PM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
ORIGINAL: AdderMk2
ORIGINAL: skinny_man18
ORIGINAL: AdderMk2
ORIGINAL: FuzzyDiceRule
i dont think hes at that part yet matt, i think he means he cant get the actual rings seated in the piston
your reading comprehension sucks
i see what he means now take it easy onme k?
I wasnt taslking to you...
BTW, are you using snap ring pliers?
oh ok sorry, yes i am using snap ring pliers
Old May 28, 2007 | 08:21 PM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
ORIGINAL: my77stang
yeah opening of the clip faces down, but that shouldnt have anything to do with the fact that you cant get the clip in[&:]
so whats youre suggestion?
Old May 28, 2007 | 10:05 PM
Jfsram's Avatar
Jfsram
Default RE: pistons
It may be as simple as install the first ring and make sure the pin is slide all the way against the first pin. If you are assembling the engine yourself. I'd assume you're past advice like this. If so,.....
Get out some measuring tools. Your wrist pin must be shorter than the inside shoulder, to inside shoulder of the grooves that hold the snap rings. If you manage to force the snap rings into place and the wrist pinis too long.It will not floatfreely.
Old May 28, 2007 | 10:06 PM
my77stang's Avatar
my77stang
Default RE: pistons
well seeing as how im guessing the pins came with the pistons like they should, and the clips came with the pistons like they should......... i dont see why he is having this problem[&:][&:][&:]
Old May 29, 2007 | 12:41 AM
F5GTS331's Avatar
F5GTS331
Default RE: pistons
yes they are the pins and clips that came with the pistons and i dont see why im havin this poblem either. its aggravating the **** out of me
Old May 29, 2007 | 01:12 AM
jtmustang's Avatar
jtmustang
Default RE: pistons
whats up man , seems like u hit a little hard spot. so your gettin close and getting the motor together. some things came up and im a little behind schedule on mine. wanted done by summer, ha ha now. just got my gears last week. dont know why i waited so long.
hope u got the right piston/or wristpin?
poke68
Dec 16, 2025 03:36 PM
uberstang1
Dec 7, 2017 07:10 AM
uberstang1
Sep 20, 2015 06:42 PM
degner122
Sep 16, 2015 07:09 AM
EASTIDEE123
Sep 14, 2015 03:52 PM
