need help with electrical...
Old 05-28-2007, 06:06 PM
stang17
stang17's Avatar
Default need help with electrical...
I have a 94 5.0 HO and its charging sysytem isnt working. i changed the alternater and it still doesnt charge . im thinking it can be the harness but not sure.. any ideas.. help anyone?
stang17 is offline
Old 05-28-2007, 07:02 PM
vt89gtvert
vt89gtvert's Avatar
Default RE: need help with electrical...
Is your battery good? And just because you changed the alt. doesn't mena the new one is good. It has happened before. If you have a volt meter then test it yourself, if you don't then it is like $10-20 at sears for a digital one, and will save you some headache.
vt89gtvert is offline
Old 05-28-2007, 07:42 PM
91smokedgt
91smokedgt's Avatar
if your alt is good and batt is good you could have a internal pcm problem. check for codes?
91smokedgt is offline
Old 06-03-2007, 11:48 PM
Hoaguestang91
Hoaguestang91's Avatar
yah same crap here, Its the alternator wires go to near where the battery is take it out and the battery tray, follow the wires from the alternator and check the color of the wire at the fuse link near the driverside where the positive batterey cable connects to the car follow the wires down that are atached to the alternator wires,there should b 2 wires that need to be replaced happend to me...
Hoaguestang91 is offline
Toddman0025
04-05-2008 02:00 AM
Quick Reply: need help with electrical...
