lopey cam
lopey cam
whats a good cam that has alot of lope? i was going to just go for something with a good sound but i decided why only go half ***. ive got an 89 gt with a 5-speed. car is stock besides exhaust. next mod will be gears then a cam.
RE: lopey cam
the motor is stock so for right now i figured a diff cam would help a little with power.i dont have the cash to build the motor yet so just want something that looks good and sounds good. so far ive just had the car lookn good.
RE: lopey cam
ORIGINAL: Jasperstang308
why get a cam just for sound why not get it for power?
if you want lopey get a cam with duration
RE: lopey cam
I ran a Summit cam in an engine years ago that chopped like Nascar. I ran it on stock heads, with stock springs. I think the advertised duration was .286 and the lift was only like .471. I was running a carbed set up. That cam was a hydraulic flat tappet. Shook the body panels of my old 4 eye at the red lights idling about 900 rpm's.
RE: lopey cam
You could use a (one cam fits all) E303 it has a good sound and average performance but is not by anymeans the best cam for a complete setup and you should always base cam from your head setup and what you want to use the car for like track or street or both many factors go into a cam selection (not sound)
RE: lopey cam
Do something w/ the stock heads before you go thru the process of putting in a cam. It will be minimal gains. The stock cam isn't bad at all...run it w/ a set of GT40's or P's (w/ larger exh valves) and you'll see much bigger gains than from any cam on the stock heads.
