0 comprssion in one cylinder
did a comp test and haver 0 comprssion in one cylinder. knew it was low but not that low. i would think that it would havea little comprssion but it didnt even move the needle. i tried another cylinder to make sure it wasnt the guage. nope that cylinder has 0 comprssion. what does everyone think. 95 5.0 100% stock
RE: 0 comprssion in one cylinder
burns oil when you nail it. but doesnt smoke driving normal. smokes a little when u first start it up. pcv pops out on occasion, but the screen looks like its covered in ****. shakes up until about 1500rpm. valve cover keeps leaking on the side of the dead cylinder.
im gunna pul the valve cover off tomorow morning and see if everything is moving properly. i cant see bad rings having 0 compression unless there is a hole in the piston lol, bc even if the rings were that bad there shuold still be some kind of compression
ORIGINAL: ant0045
the chances of him all of a sudden having 3 bad rings are very slim..
even if the compression ring blew, the oil rings would have moved the needle on the gauge at least a little bit...
he said it didnt move at all.
sounds like a stuck open valve to me, probably intake.
