wtf
Old May 29, 2007 | 11:48 PM
red94gt's Avatar
red94gt
Default wtf
my car makes this noise when you get it over 3grand and when you let off the check engine light comes on but if you go over 3grand in neutral or park dont make noise and the check engine light does not come on any suggestion
thanx
Old May 29, 2007 | 11:52 PM
85GTsleeper's Avatar
85GTsleeper
Default RE: wtf
what kind of noise, can you be a little more specific por favor
Old May 29, 2007 | 11:56 PM
red94gt's Avatar
red94gt
Default RE: wtf
like something falling apart or a fast knock hard to exp
Old May 30, 2007 | 02:15 AM
94StinkinLincoln's Avatar
94StinkinLincoln
Default RE: wtf
running lean?
Old Jun 16, 2007 | 05:55 AM
ezekiel's Avatar
ezekiel
Default RE: wtf
It must be a rod knock. It is caused by extreme bearing damage. If the rod bearings are worn or loose enough to make a dull, hammering noise, you're driving on borrowed time. Bearing noise usually happens inhigh mileage engines.Ithappened to my previous carwhenI have not had the oiland Mazda oilfilter changed regularly.
Old Jun 16, 2007 | 11:27 AM
5.0stanger's Avatar
5.0stanger
Default RE: wtf
I geussing it is predetonation. What is your timing at? Run your codes lately? Try running higher octain fuel
xdef00
Feb 27, 2004 03:18 AM
