tocan you?
yes. you will need a blow through carb but its doable. there is a lot of info on forced fed carbs here http://www.theturboforums.com/smf/index.php?board=13.0
read around on turbomustangs.com all the turbo info you can handle.
boost pressure is not the issue, its the hp that is. the stock block will take about 450rwhp and then you have problems. 450hp is the same no matter if you make it with 5psi of boost or 15psi
