ran KOEO and KOER test HELP!!...
i fixed the ecm as my previous post said but it runs like **** now so i just ran a KOEO and KOER test to my stang, i'm desperate here are the codes i got
KOEO
ACT/VAT -40F
54
CANP FAILURE
85
FUEL PUMP SECONDARY
95
KOER
FMEM/RETEST
98
ACT/VAT -40F
54
PLEASE HELP!!! My wife says i spend to much time on my car, that i should buy a new one to don't have problemsand sell mine, i don't want, guys save my stang please!!
if you can give like a dummies descripsion of the codes, i'll apreciatte that,i feel like a fckin beaner all the way for not understandin'em
KOEO
ACT/VAT -40F
54
CANP FAILURE
85
FUEL PUMP SECONDARY
95
KOER
FMEM/RETEST
98
ACT/VAT -40F
54
RE: ran KOEO and KOER test HELP!!...
Sure.....
98 at KOER means the system will not allow the full KOER routine to run until code 54 is fixed.
Code 85 = CANister Purge solenoid circuit.....is it connected or was it removed deleted.....I mean the solenoid on top of the canister filter shown below......
For code 95, clear codes first and check if it shows up again.....FYI.....Code 95 possible causes are:
[ul]- Inertia-fuel cutoff switch is open (when inertia switch is part of the primary or "relay activating" circuit)
- Open wire between the FP relay and ECM pin 19 (FPM signal)
- Bad FP ground
- FP relay stuck closed (FP on all the time even when ignition is off)
- FPM signal wire shorted to VPWR
- Faulty ECM
[/ul]
- Bad FP ground
- Faulty ECM
[/ul]
i checked the ACT but its located in front of the #1 injector i guess someone had it that way on the explorer intake, i'll change that sensors and see what happens
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
