front control arm squeak
Old Jun 1, 2007 | 12:30 AM
PRO50SC's Avatar
PRO50SC
The Rogue Mod
Default RE: front control arm squeak
ORIGINAL: PRO50SC
How do you know it's the control arm? And for a beginner, I wouldn't recommend doing it.
Might try answering the right questions first. May help save some time, money and aggravation!!!
Old Jun 1, 2007 | 12:31 AM
HACKGT350's Avatar
HACKGT350
ORIGINAL: blkonblk5.0
ORIGINAL: redemption
pb?
pb blaster...it breaks anything loose! and it will eat through stirafoam!
haha it sure does i used to entertain myself doing stuff like that at work when there was nothing to do
ORIGINAL: OnyxCobra
Are you sure it's not just the ball joints?
i was thinking the same thing. mine started squeeking and i just didnt pay attention till the ball just snapped and the same thing happend in my buddies 95
Old Jun 1, 2007 | 12:38 AM
redemption's Avatar
redemption
ya im sure i put my ear up to it
Old Jun 1, 2007 | 12:45 AM
HACKGT350's Avatar
HACKGT350
putting your ear up to it doesnt work trust me. they make tools to listen for stuff like that head phones with a thing that listens for the sound and it aplifies it for you
Old Jun 1, 2007 | 05:18 AM
Jfsram's Avatar
Jfsram
ORIGINAL: Grundy
ball joints are known to squeek when they sease up.
I thing Grundy is trying to say seize up. Anyways that's correct and the next step is the ball joint breaks and you are sitting on your lower control arm.
Control arms don't squeak. It's either the lower control arm bushing or ball joint.
Old Jun 1, 2007 | 10:31 AM
HACKGT350's Avatar
HACKGT350
ORIGINAL: Jfsram
ORIGINAL: Grundy
and from stories and past experience its most likely your ball joint. they are known for going in these cars. mine went at 164k my friends went at 80k so its very likey its the ball joint. just sitting in your car you can have them squeak
Old Jun 1, 2007 | 10:48 AM
P Zero's Avatar
P Zero
Ok first off, the bushings on the front control arms will NEVER squeak. The steel collar that bolt goes goes through is locked into place as soon as the bolt is tightened. And the bushing does not have enough movement to squeak.
Your balljoint is bad. Easy way to check if its the balljoint, with the car running but not moving, move the steering wheel left to right about 1"-2" each way kinda quickly. If you hear the squeak while doing that its DEFINITELY the balljoint.
Foxbody balljoints will NEVER be loose. The way theyre designed is they recess inside of itself. If you look at the bottom of the balljoint (the grease cover portion) it should be semi-circular. That is the WEAR INDICATOR. If its almost flat, meaning not semi-circular, the balljoint is worn out and needs to be replaced.
Ford recommends that you replace the whole lower control arm. But press-in balljoints are available from aftermarket suppliers. I'd recommed that youreplace the whole arm, that way you get new bushings and all. Maybe some Ford racing ones with improved bushings.
-P.
Lethaldosage423
Oct 19, 2015 12:12 AM
svfetter
Oct 5, 2015 11:39 AM
ThatJuanStang
Sep 25, 2015 08:01 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
