i need help!!
i need help!!
last night my headlights went out and i have the slightest idead why i tried jiggling the headlight wires and checking to see if anything was unplugged i dont thinks its a fuse because all my other tail lights and side marker lights still come on its just my just beams which are my regular light wont come on can any one help
p.s. and my speedometer is jumping all over the place is my speedometer cable broke or something?
and where can i get a fuse box panel diagram
1991 Ford Mustang 5.0 LX
RE: i need help!!
"Have you actually taken out the h/l switch to look at the wiring/connector on the back of it. They do have contact problems that melt and cause failure. "
No i kinda dont know where to be looking for that exactly umm any suggestions where to look?
RE: i need help!!
ORIGINAL: PRO50SC
Those h/l switches dont like to come out easily. There are 4 tabs holding it in, two on each side and they all have lil teeth on them.
Your speedo cable probably needs lubed or replaced. Dirt or a bad cable will keep it from spinning smoothly.
