Novi 1000 for sn95
RE: Novi 1000 for sn95
ORIGINAL: stang8689
dude mustangs unlimited has the novi 2000 for under 3200 don't get the 1000
ORIGINAL: 92hatchLX
I wonder if you could just purchase the mounting kit, and buy the novi 1000 head unit. I doubt that it would be any cheaper though.
Yep, the Novi 1000 that I got will push around 15 pounds of boost at sea level. Especially with the pulleys and the powerpipe that I got with it. I'm going to just run the stock pulley that comes with it and the stock crank pulley and put the AFM powerpipe on, it should produce around 5 psi (I'm at 5500 ft. elevation soit won't produce as much boost compared to sea level)which is enough for me now. I'll swap the pulleys when I can afford a real tune, injectors and a matching MAF
ORIGINAL: CrazyCobraSpeed
i found a novi 1000 for a 94-95 at superchargersonline.com... its 3grand tho.... were else can u get paxton supercharger and how much is a novi 1000 for a fox???
