what brand caster camber plates
RE: what brand caster camber plates
Not to get off subject, but are all c/c plates adjustable... Cus when i took mine for an alignment just recently, he said he couldn't get it aligned perfectly. I told him about the plates and he said they weren't adjustable....
ORIGINAL: 5Liter Import Eater
ORIGINAL: stang8689
you broke a bbk c/c?
my car spun into a curb at about 30~ mph.
broke a c/c plate
broken wheel bearing
bent rim
i think any faster and i would have bent the strut tower.
yea i thought they were adj, i could see right on them how u can adj them. when he came to me and said he couldnt get it perfect, i was like he probably didnt even look at the c/c plates, thats when i was like did u adj the c/c plates and he said they werent adjustable. i was like are u sure cus they're supposed to be and he said no. it was the first time i went there but i'll never go back again.
town fair tire only does "toe-and-goes" meaing they wont even pop ur to hood to check if u got c/c plates.
they just simply adjust toe to spec and they're done.
where did you go?
where did you go?
ORIGINAL: 93 LX FiveO
where did you go?
where did you go?
but the majority of the cars that roll though do not have such adjustments
This is a great thread because not all plates are created equal. Good to hear which ones are working out. I saw on another forum a 94 or newer. The strut damaged his hood when the bearing failed. Don't remember which brand that was.
What are you guys setting your front ends to.
Camber, caster and toe.
