Benefits Carb to EFI
Old Jan 1, 2005 | 05:24 PM
nemethjames1's Avatar
nemethjames1
Default RE: Benefits Carb to EFI
your cam starts making your hp #'s go downhill after around 5100rpms give or take... you still have pull at 6400 but it aint as much as 5000........ i liked carbs when i had my 240-280z's but when it comes to the 302 i'd take efi hands down
Old Jan 1, 2005 | 05:29 PM
pipeliner's Avatar
pipeliner
ORIGINAL: nemethjames1
Correct it does but as long as it keeps pulling I need the RPMS
Old Jan 1, 2005 | 05:31 PM
nemethjames1
you'd be quicker in the 1/4 if you shift at its peak power......
Old Jan 1, 2005 | 05:36 PM
pipeliner's Avatar
pipeliner
I dont 1/4 mile I autocross big differnce
Old Jan 1, 2005 | 05:38 PM
nemethjames1
ahh ya i c..... ever thought about gettin another carb?.... if you got like 600 bucks you could get a efi intake, puter, and maf, and harness and you wont have that prob (maybe).... converting to efi aint cheap, and i'd go mass air....
Old Jan 1, 2005 | 05:49 PM
vfast's Avatar
vfast
I ♥ Acer
if this is a small corse then having the right gear is very impotant...the 600 carb can be massaged to 670 or so....also making a small vacuum leak will help with more gas..a round track trick..which if caught isn't good.....I would mill the air horn if your class permits..also you can dill out the lil 4 holes you see looking down in the carb to give a 4 corner like tune
Old Jan 1, 2005 | 07:01 PM
mstng675l's Avatar
mstng675l
hell dont go to an efi...just get a good carb such as holley or demon with mechanical secondaries.. then get a good tune with the right jets and you will be set...
Old Jan 1, 2005 | 07:43 PM
vfast's Avatar
vfast
I ♥ Acer
carb all the way....about a million reason to..
Old Jan 1, 2005 | 08:37 PM
pipeliner's Avatar
pipeliner
ORIGINAL: mstng675l
I have a good carb it is a Holley. And its juned the best a carb can
Old Jan 1, 2005 | 09:31 PM
mstng675l's Avatar
mstng675l
what i am saying is get mechanical secondaries... they open up as soon as the pedal is to the floor...
