Alignment specs
Old Jun 4, 2007 | 10:21 PM
mopman93's Avatar
mopman93
Default Alignment specs
alright, im doing springs, shocks, rear lower control arms, and caster/camber plates in the stang. does anybody have a good like default caster or camber angles that are good for the street? Or what do you recommend for my adjustment? POsitive negative camber? caster? whats the best for handling and street driving
Old Jun 4, 2007 | 10:53 PM
945LSTANG's Avatar
945LSTANG
Default RE: Alignment specs
i recommend getting an alignment professionally done.
Old Jun 4, 2007 | 10:56 PM
stang8689's Avatar
stang8689
get the strut as straight as possible for now then get an allignment not that much
Old Jun 4, 2007 | 10:58 PM
mopman93's Avatar
mopman93
yeah but liek which is better more postive camber? or more negative camber? liek does anybody know the setup on their car that works well?
Old Jun 5, 2007 | 12:12 AM
93 LX FiveO's Avatar
93 LX FiveO
positive caster will give the car a better feel at higher speeds
have to jackup the front-end while adjusting the plates which makes it harder to get it accurate
Old Jun 5, 2007 | 03:28 AM
Jfsram's Avatar
Jfsram
Defintately go positive caster. 2-4 deg.
As for camber. Always negative. How much is going to depend on how much you are willing to sacrifice in tire wear vs handling. More = more. If that makes any sense to you.
Toe is 0 for tire life. Toe out for solo parking lot style racing, toe in for high speed.
winner99
Sep 30, 2015 07:04 PM
UrS4
Sep 30, 2015 10:13 AM
Drastang
Sep 29, 2015 03:31 PM
marc954
Sep 29, 2015 11:18 AM
lincolnshibuya
Sep 24, 2015 10:46 PM
