New 351 intake pics
New 351 intake pics
Pretty trick looking
just running into fender airfilter now, but will be reused with turbo install.
Had to put 1" spacer under the Coast High power elbow and chop it up to move TB back 2.5" for hood
clearance. Just clears my 4" hood
Maybe polish the CAI and power elbow some day.
RE: New 351 intake pics
ORIGINAL: Ahnial8u
So what do you do with all the Vacuum hoses? Just plug them up? It looks nice under there.
on the back side one big Vac connection.
ORIGINAL: my77stang
whats going on with the 3 piece upper radiator hose?[&:]
It works fine this way and looks a LOT better with little hose rub protectors hiding clamps
Check out old set-up, same thing but looks "factory".......... I'll put them back on later.
ORIGINAL: Jasperstang308
looking good r.barn
how much longer do you have until it will be done?
looking good r.barn
It's been raining a lot here. If it stays dry this weekend
I'll get the battery moved and start re-routing some wires and such to make room.
The fab. work once I get everything cleared out of the way should go
pretty quick. My layout is going to be pretty simple
I've got a good bit done so far.
1. p/s pump removed and manual rack installed
2. intake swap
3. intercooler pipe into fender well.
4. AEM computer installed to tune the beast
5. oil pan already tapped for return
did you just throw a carb lower intake and an elbow on that? i looked at that for a while and was trying to understand cuz i saw a carb lower but then saw a TB and fuel rails lol
