pulled codes
Old Jun 6, 2007 | 09:52 PM
nacanitihs's Avatar
nacanitihs
Default pulled codes
i used the tecknique that adder said to use in annother post..
i got a 31 and a 67 i believe.. what do these mean cuz i cant find a list
thanx
Old Jun 6, 2007 | 10:10 PM
Blckstng93's Avatar
Blckstng93
Default RE: pulled codes
31 - EVP circuit below minimum voltage (KOEO, KOER,continuous code)
67 - Clutch switch circuit failure (continuos code)
- Nuetral Drive Switch circuit open, a/c input high (KOEO, KOER)
The EVP is the little white piece on the EGR valve. Check it for corrosion.
Old Jun 6, 2007 | 10:29 PM
Blckstng93's Avatar
Blckstng93
If you havent yet, pick up an 89-93 Chiltons. Theres a list of codes on 4-37 and 4-38.
Old Jun 6, 2007 | 10:32 PM
Joel5.0's Avatar
Joel5.0
or simply go to http://fordfuelinjection.com/?p=14
For 31...do you have the EVP disconnected? ..... EGR is still in place?
For 67....was the tranny in gear when you ran the KOEO?....if yes, put it in neutral and rerun the test....if no, push the clutch pedal and leave it pressed while a KOEO is run.
Old Jun 6, 2007 | 11:33 PM
nacanitihs's Avatar
nacanitihs
i still have the EGR.. i had it cleaned cuz there was some scillicone blocking the valve or something.. so what should i do about the 31 code?
and joel ill try it w/ the clutch in
Old Jun 7, 2007 | 12:06 AM
Joel5.0's Avatar
Joel5.0
As long as you apply vacuum to the valve and it opens and closes when released, the valve is OK....the problem would be a bad EVP sensor, or an open in the EVP wire to the computer....you would have to check the voltage by probing the EVP signal wire, using the SIGRTN wire as your ground reference with the ign on (same as you would do with the TPS)....if the reading is below .24 vdc....check the VREF wire, if the reading is 4-6 vdc....the EVP is kaput.
Old Jun 7, 2007 | 01:04 AM
nacanitihs's Avatar
nacanitihs
alright i did it again w/ the clutch in and only the 31 came up...
ill check the voltages tomorrow... what is the ign? also where is the EVP located? most likely near the EGR but what does it look like?
Old Jun 7, 2007 | 01:08 AM
mattdel's Avatar
mattdel
http://fordfuelinjection.com/?p=35
Old Jun 7, 2007 | 01:19 AM
Blckstng93's Avatar
Blckstng93
ORIGINAL: nacanitihs
ORIGINAL: Blckstng93
IGN is short for ignition.
BOB ROME
Jul 26, 2023 01:54 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Urambo Tauro
Oct 5, 2015 09:37 PM
Dathan
Oct 5, 2015 05:52 AM
ChampInSD
Oct 2, 2015 04:55 AM
