changing the freakin pulley?
Old Jan 2, 2005 | 02:48 PM
sykopafikjuggla's Avatar
sykopafikjuggla
Default changing the freakin pulley?
Ok i got a 91 LX 5.0. I got the ford racing pulleys for xmas. Im stuck tho, becauseright now Im trying to remove the alternator pulley and it wont come off. Impact wrech, ratchet, hand tools... nothing... i doubt i am doing anything wrong. Any suggestions?
Old Jan 2, 2005 | 02:51 PM
91hatchgt's Avatar
91hatchgt
Default RE: changing the freakin pulley?
I've always used an impact, mine came right off.. Don't mean to sound sarcastic, but are you sure you have the impact in the back-out position. One other thing, try spraying some WD-40 on there, or some liquid wrench, stuff works wonders. Good luck.
Old Jan 2, 2005 | 02:57 PM
sykopafikjuggla
Yeah I got it on the back out position =] I tried wd40 also. I guess my main thing is, it wont budge but also the belt moves little by little. The impact gun is kind of hard to fit down in there, so my best thing is the ratchet.
Old Jan 2, 2005 | 03:02 PM
91hatchgt's Avatar
91hatchgt
OH, you still have the thing in the car!? I have always taken the alt. out of the car to change the pulley on it.. It is much easier I'll tell ya.. Only takes a few more minutes, and less headache.
Old Jan 2, 2005 | 03:47 PM
mdvaldosta's Avatar
mdvaldosta
I ♥ Acer
no way to remove it other than using an impact, its easier to keep the belt on when you do it.
Old Jan 2, 2005 | 03:58 PM
StangerGT's Avatar
StangerGT
yeah leave the belt on and use an extension and a 1/2 universal jointon the end with the socket. and hold the extension the direction you wanna take it off so the impact gun hits it and isnt bouncing the socket on the nut. and it should come off. unless your impact gun is weak, if thats the reason youll never get it off. i had to go buy a new impact gun to get it off.
Old Jan 2, 2005 | 04:20 PM
Dbeck002's Avatar
Dbeck002
I ♥ Acer
i used a ratchet and a breaker bar. you need to make sure the alternator does not rotate as you rotate the ratchet or else you wont get anywhere!!! use a breaker bar for more torque and lock the alt fan.. should come off..
Old Jan 2, 2005 | 04:57 PM
primetime5.0's Avatar
primetime5.0
i stuck a screw driver inbetween the fan and the alternator to get mine off
Old Jan 2, 2005 | 06:56 PM
sykopafikjuggla
thanks for all the help guys. i had a new alternator sittin in the garage so i just took the pulley off that and put the new alternator in.. thanks !
spdeplayer2
Oct 24, 2015 09:45 AM
FivePointToTheOh
Sep 29, 2015 12:53 PM
mikesr4565
Suspension
Sep 21, 2015 10:26 AM
ctgreddy
Sep 20, 2015 08:35 PM
Mobiusone stang
Sep 7, 2015 08:46 PM
