Airpipe! Please READ!!
the airpipe coming from my smog pump will not come off my h-pipe. will i fail emissions if i cut the mf out?! im starting to get frustrated and need an answer. i live in missouri btw.
RE: Airpipe! Please READ!!
it will pass the sniffer, but if there is a viz you will obviously fail
i almost passed a sniffer test in cali w/ long tube headers, off road h-pipe and deleted smog
you will need to pull the whole smog pump and accessories off though...other wise it will make noise , takes about 1/2 hour total, and you'll have as much clearance on the pass side to change plugs as you do the rt side
i'd do it....oh wait i did that on all my mustangs
there is no visual inspection in missouri. just the sniffer. would it work if i cut it and use tape (lol, dont want to weld it)? what is involved in a smog pump delete??
