Temp
Old Jun 10, 2007 | 01:22 AM
kevman41635's Avatar
kevman41635
Default RE: Temp
Is 230 to hot i know its hot but could it hurt anything
Old Jun 10, 2007 | 01:26 AM
15austin's Avatar
15austin
Default RE: Temp
I use 180 in summer and 195 in winter.
Old Jun 10, 2007 | 01:32 AM
backfire2007's Avatar
backfire2007
Default RE: Temp
Im running a summit alum. radiator w/ dual puller fan new water pump and a 180* t/s and the temp. will not rise above 180 even when I beat it like a redheaded stepchild so dig into your pocket lol
that $hitty stock radiator is worthless and you can take that to the bank
[sm=closed.gif][sm=closed.gif][sm=closed.gif][sm=closed.gif][sm=closed.gif][sm=closed.gif][sm=closed.gif]
Old Jun 10, 2007 | 01:40 AM
kevman41635
Default RE: Temp
All i am wanting is around about number. I know what i have to do to fix my car and it is change the t stat but i can not change it till i drive about 2 hours home from my moms. So i was just wanting a number to know when i should stop and let it cool off.
Old Jun 10, 2007 | 02:46 AM
jasonvri's Avatar
jasonvri
I ♥ Acer
Default RE: Temp
With a one time over heat you are fine til 250F.
Repeated over heats will do more damage, and risk of detonation increases at higher temps...
The motor won't just blow up at 251F. However, the RISK increases dramatically as temps rise.
Start getting nervous around 220F. Below that isn't anything to worry about.
I prefer to keep my stable temp as high as possible, 200F, using a 195F stat.
Keeping the temps above 180F will improve power, economy, and decrease cylinder bore wear.
There is nothing wrong with the factory radiator. I have used one in my 408w for several months. If the cooling system is well maintained, the factory unit is more than adequate.
The only way to know the temps you are running at is with an aftermarket gauge. The stock gauge is not accurate enough to use for more than reading 'hot' or 'cold'
My random thoughts,
jason
67LimeCoupe
Nov 25, 2015 08:55 PM
Spiral534
Oct 6, 2015 04:31 PM
AMAlexLazarus
AmericanMuscle.com
Sep 23, 2015 01:14 PM
Pyrate Dave
Sep 10, 2015 07:30 PM
96stang3.8
Sep 10, 2015 06:42 AM
