maf problems
maf problems
ok i have a 87 lx that has been converted to maf the problem that iam having is that when you run the car with maf disconnected it runs fine as soon as i plug in the maf it starts running like sh** and stalls i have a supercharger on the car could it be that because the supercharger belt is off the car isnt getting enough air the maf is calibrated for 24lb injectors and thats what i have and ideas what the problem could be.
RE: maf problems
ORIGINAL: 1fast5.0
Is the MAF cal'd for this ecu?
Disconnecting the MAF will tell you absolutely nothing.
You need to start by pulling the diagnostic codes, and see what you get from that.
24's are likely too small for a decent amount of boost...
jason
RE: maf problems
Same problem with my 93 cobra.. Had a supercharger and it ran fine, I decided to take the superchrager off. It had a "big Air" Maf 6 wire maf.. I spliced the stock harnes for a 4 wire maf.. And I also took an extra chip that was added to the computer off..
It has the exact same problem as yours.. Idles fine without maf, as soon as i plug it in, the car starts to die...
I had it diagnosed, it came up with code 66, and 94..
66 = low maf voltage pin c
94 = Sumtin about hardline malfunction....
RE: maf problems
ORIGINAL: navmust
RE: maf problems
Thanks man, I will check the connections real good.. The maf does get the ground, main voltage "12v", and like you said, the next reading which I think is pin c gets all kinda weird readings.. I'l try to check my connections asap and i'l see what happens...
I know its supposed to get .6v at idle and 2 volts at about 60mph...
