tapping bolts
make sure you have the right tapsize and just start the tap by hand and you can either tap it with a proper tapwrench (t-handle or handle) or tap it with a set of adjustable wrenches. just make sure the tap is going in straight. o yeah and lube the hole some with something other than hydraulic oil or synthetic motor oil. cutting oil is usually best but in a pinch used motor oil is great. o yeah make sure you have a hand tap/ 4 flute tap not the 3 flute machine tap. if you really want to be ballsy and since it's a thru hole power tap it with a hand drill. easy outs can come out if you break them. there's no material made that can't be machined.
ORIGINAL: MadMan@TheWheel
Easy out's. That is the best way to get seized studs out of anything. A $10.00 investment. Try that before you put a torch to them though, you will actually harden them with a torch making drilling a bit tough.
ORIGINAL: ACE
Vice Grips FTMFW! Mine came out with an airgun and a swivel but make sure you get the impact swivel or you get new dents in your head[:@]
I would get a product called "PB Blaster and put that on the bolts overnight.
Then, I would try the vice-grips. I'd use the ones that are about 8-9" long with the curved jaws.
If that don't work, get a LEFT HANDED drill bit and carefully center-punch the bolt and then with the drill in reverse, drill it out.
Lotsa times the left hand drill bit will catch the bolt and bring it out...........
Good luck...........
I can't believe you actually asked how to use vise grips. They are locking pliers... lock them on the bolt head and turn them to unscrew the bolt. And as far as I know, tapping is not to remove a bolt. Tapping is when you drill a hole into a piece of metal and run a tap into it to make threads in the hole so you can screw a bolt into it. A die is used to put a thread on a metal rod so it can be screwed into a hole. An easy out is used to remove a bolt by drilling a hole into the bolt and then screwing the reverse threaded easy out into the hole and un-screwing the bolt. But like said above, they tend to break and cause a bigger problem. Use vise grips and lots of penatrating oil and some heat from a torch if needed. If vise grips don't work, I've taken a dremel and grinded on the head of the bolt until it has two flat sides opposite from each other and used a wrench to remove the bolt. If that fails, I've taken my dremel and cut a slot on the head of the bolt and put a flat head screwdriver bit on theend ofmy impact wrench and taken bolts out. If that doesn't work, I get the torch out and burn the head of the bolt off and us the vise grips to get the rest of the bolt out.
