Timing Chain Cover
Hey guys, I have one really quick question.
For all of you that have done cam swaps and have had to remove the timing cover, my question is this:
I'm having a couple of radiator leaks under my hood. One is at the thermostat cover, which I know I can fix when install my new Cobra intake later on this week. Another possible leak is on the lower intake, yet again, will fix itself. I know I can do this project with little to no problems, however there is one last leak left, at that's at the timing chain cover. I've done a little reading up, and while most of the parts look like just basic bolt off and on procedures, I was wondering if this is something that a novice mechanic should try to do. I have mechanical skills and no how, but never have I played with water pumps, power steering pumps, and the harmonic dampener. So is this a job that I can do along with my intake, or should I just do my intake and have a shop do the timing chain. I love to do my own work, but the whole damn 12 step procedure out of the Haynes manual seems obtainable, I'm just a little leary on a few parts.
Oh, I'm using actual gaskets. Whomever broke my engine apart to install the cam and the stroker kit used that gasket crap in a tube and, well, as you may know, while it's OK for the short term, over time it breaks down and starts leaking.
Not hard.....I am no mechanic....and I did it no problem....
The timing chain coveris intimidating because there are three different seals for the same part....
Here is a link to directions for an H/C/I install....just skip to the part for the reinstallation of the timing chain cover and you should be good.....
http://www.allfordmustangs.com/techa...intakeswap.pdf
Good Luck!!
Good Luck!!
musnicki
Sep 23, 2015 07:11 AM
