rear end
rear end
when i converted to a 5.0 in my 94 v6 i left my v6 rearend in the car. I need to get an 8.8 inch rearend. So my question is, if i get a rear end out of a fox body will it fit? And if it does, can i get the axles out of my v6 rearend that have the disc brakes and put them in the 8.8 ?
RE: rear end
actually the only thing that makes the rear end wider on the sn-95 carsare the axles. they are 3/4'" longer. the fox body guys often use sn95 axles on their cars to use the rear disc brake setup. they just have to use a different offset wheel. the axles themselves on the sn95 cars are all the same length, diameter, and spline size no matter if it is a 7.5 or an 8.8 rear end. just keep the axles and brackets from the 7.5 and use them on the 8.8 to keep the right lug pattern. this is actually the conversion i am doing on my car.
Dragonus18
09-09-2015 01:21 AM
