u need lifters and maybe timing chain dependion on how loose it is. You could replace the bearings but it requires a special tool, usually a machine shop does this. You also don't need a new thrust plate. Definitely not pushrods unless one is clogged or bent.
Pushrods are ok, the stock lifters wont work or just need replaced when doing a swap? I'm not doing the swap my uncle is and said to order bearings with it.
usually u wanna replace lifters because the mate with each lobe of the cam. that's y u keep them in oreder when u take them out if ure reusing the cam. You don't need to do bearings
Hardened pushrods are only required with non self aligning rockers(adjustable) that use guideplates. Otherwise it's a waste of money. Unless u just wanna say u have hardened pushrods? hahaha
u don't necessarily need a timing chain, only if it's worn out. If it has alot of slack then replace it. If the car has a lot of miles then u'll probably need one n e ways.
