Where to get complete Top End kits?
RE: Where to get complete Top End kits?
You could also check Camshaft Innovations, custom cam, Canfield or TFS heads with the correct valvetrain components to support the cam, lifters, timing set, etc, etc.....based on the level of performance you're looking for.
Nope....provided you install the correct cam and valvetrain.
ORIGINAL: 87foxgt
is there something like to big of head for a 302 http://cgi.ebay.com/ebaymotors/SBF-Z...17534357QQrdZ1
ORIGINAL: Joel5.0
ORIGINAL: 87foxgt
I can't believe he said trick flows don't perform. I guess everyone is on the AFR bandwagon now because of flow numbers. They did nothing to the combustion chamber. It's just a standard wedge head with some good ports.
you cleared it up alittle but what are the pro's and con's to aluminum heads and porting. and here's a big noobie one for you but i most ask is porting the same as board out the pistons ?
Aluminum heads are lighter and dissipate heat better. Which means u should run a lil cooler and u can put more timing into the motor before detonation. Dissadvantage, aluminum becomes brittle after many heat cycles
165 is the highest u can go without notching the pistons. Acoording to adder it's easy to do and n e machine shop can do it. Around here no machine shops do it, so I really don't agree. They only make one size track heat head, unless it's the ported version which is a 185 instead of a 170. Mine are 170
