compression test results
RE: compression test results
There's quite a bit of variance, 139 - 158. Did you let the needle bounce 5 times? But as for your compression results, the ones in the 130's are kinda low IMO. Sounds like she could use a rebuild.
-P.
-P.
you might want to do a wet compression test. squirt a tablespoon worth of oil in the cylinder and see if the numbers substantially improve on those couple low cylinders. if they do, you need rings. if they dont, you need valvetrain work.
no lol its one of the projects that i have to do for my auto class at school, thought i might as well check my car, the engine seems to run great so no particular reason, also thinking i might not of been cranking the first few cylinders long enough, what should the stock reading be?
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
GT350 S550 Tech
09-29-2015 03:29 PM
