Car Died...
Old Jun 13, 2007 | 08:25 PM
MustangMadness7's Avatar
MustangMadness7
Default Car Died...
I was at the mall, when I went to start my car up to leave, it wouldnt turn over. Its not the starter or the battery. The fuel pump was just replaced last year. Anyone have any ideas of what it could be?
Old Jun 13, 2007 | 08:27 PM
mattdel's Avatar
mattdel
Default RE: Car Died...
ok, for everyone out there that reads this thread:
doesn't turn over means DOESNT CRANK.
please learn the lingo before you type.
now... explain a little more...
Old Jun 13, 2007 | 08:28 PM
93 LX FiveO's Avatar
93 LX FiveO
did u check for fuel? poke the shrader valve with a paper clip or something
need to check for spark too...
good places to start and then get back to us
Old Jun 13, 2007 | 08:37 PM
mustang5_0gt's Avatar
mustang5_0gt
u may also have a bad relay
Old Jun 13, 2007 | 09:27 PM
92hatchLX's Avatar
92hatchLX
Have you tried jumping the starter solenoid? Have you actually tested the alt. and battery?Haveyou tested the batteryunder load?
Old Jun 14, 2007 | 01:23 AM
302f150's Avatar
302f150
if it wouldnt turn over, he means its completely dead. therefore he doesnt really need to worry about spark or fuel delivery on a motor that isnt spinning.........somethin drained the battery, easiest way to check is to charge it, and do a parasitic draw test, have someoen watch the meter, and start pullin fuses/realy. when the draw drops u found the biggest drain......which prolly killed ur car........u didnt leave the lights or radio on did you?
Old Jun 14, 2007 | 01:28 AM
302f150's Avatar
302f150
well.......does any of ur lights come on ur dah when u switch the key on? anything? if they do, and u hit the key and nothin happens, but all the lights die/get dim, ur starter is pullin too much current, which usually means its shorted/locke dup.starters have absolutely minimal resistance when they arestandin still, which is basically a short.if nothin happens at all when u turn the key on, then u need to check the solenoid and all to see if the starter is gettin the command to turn
Old Jun 14, 2007 | 01:39 AM
nacanitihs's Avatar
nacanitihs
how can you rule out the battery? ur battery might just be completely dead.. happened to me i had no acid left in the battery.. somehow even jumping it for like 10+ min didnt do anything.. try popping it if you have a 5spd
Old Jun 14, 2007 | 02:00 AM
rcdblink716's Avatar
rcdblink716
It wouldn't start or it wouldn't turn over? Two completely different things. If it won't turn over then the fuel pump isn't relevant plus I think people overlook that a brand new part could be bad, it happens all the time.
Old Jun 14, 2007 | 02:04 AM
VigCS's Avatar
VigCS
He said in the first post it won't turn over. Meaning the starter won't crank the engine. Meaning there's no motion under the hood.
djbigskrilla
Sep 20, 2022 01:04 AM
chain
Aug 17, 2015 08:52 AM
92 5.0stang
Aug 13, 2015 06:46 AM
Milan Dragway
Aug 12, 2015 03:43 PM
ccwebb
Aug 11, 2015 06:47 PM
