Supercharger question
will a stock 302 hold 14lbs of boost? I'm lookin at anderson fords vortech sq trim supercharger kit. Do you think this isa good deal? $2995 Anderson ford power pipe
SQ trim kit
FMU for 38LB injectors
255lph t-rex pump
Mallory ignition with map sensor
2.95 upper pulley 7 lower
SQ trim kit
255lph t-rex pump
RE: Supercharger question
that doesnt sounds like a great deal... a sq goes for like 2400 i think... at least for a sn95.... and a power pipe is like 150ish?? have to double check on that... id get a tuner kit and just buy the power pipe seperately... u dont wanna use a FMU newayz and and u really odnt need the other stuff either... well the fuel pump is kidna nice... but ull still need injectors... and if u use that fmu ull need 38 lb injectors... which i personally dunno were to get them... ive seen 36 and 39... to be honest must s/c kits are a waste of money cuz u dont use all of it... a tuner kit is a better beat... check out superchargersonline jdsperformance and superchargerforsale.... they are the best deals on s/c ive seen.... and vortechs are nice but u have to tap the oil pan so u might want a ATI procharger.... i ahvent descided between the too personally... if i had a fox like u id get a novi 1000.... im pretty sure they can handle more than a stock engine could... so why go ne bigger?
ORIGINAL: Mustangkiler
Why would you need any fmu if you have bigger injectors, doesnt make sense?
treesloth
09-28-2015 07:03 AM
