adjusting throttle cable?
Old Jun 15, 2007 | 12:25 PM
88MustangGX's Avatar
88MustangGX
Default adjusting throttle cable?
ok since my idle is high(1200) what do i do to adjust that to knock it down to where it should be? thanks
Old Jun 15, 2007 | 12:31 PM
mattdel's Avatar
mattdel
Default RE: adjusting throttle cable?
you can try adjusting the idle set screw, but if the butterfly is already closed its not going to help.
Old Jun 15, 2007 | 12:33 PM
mattdel's Avatar
mattdel
this is what the whole deal looks like... this is an actual view. the screw is underneath the throttle body.
Old Jun 15, 2007 | 12:38 PM
88MustangGX
awesome, thanks man! now since my idle also "surges" (fluxuates from 500-1500) could that be an issue as well? or is that the IAC by itself?
Old Jun 15, 2007 | 12:40 PM
mattdel's Avatar
mattdel
could be the IAC, could be a vacuum leak, could be a dirty MAF.
Old Jun 15, 2007 | 12:42 PM
88MustangGX
cant be MAF i don't got it haha 88 has Speed density. I'll check out the other things. thanks again
Old Jun 15, 2007 | 12:44 PM
mattdel's Avatar
mattdel
ah right, 88.
reading owns me today.
Old Jun 15, 2007 | 12:45 PM
Joel5.0's Avatar
Joel5.0
DIY KOEO/KOER/Cylinder Balance Self-Test
Old Jun 15, 2007 | 03:32 PM
7upedition's Avatar
7upedition
musclemustangs.com... rough idel tech article: set tps, base idle, clean iac, etc. check for vacuum leaks
good luck
Thunderball
15
Nov 22, 2015 11:49 PM
kevsgt
Oct 9, 2015 10:12 PM
UrS4
Oct 3, 2015 06:23 AM
breaking
Oct 2, 2015 01:27 PM
winner99
Sep 30, 2015 07:04 PM
