O2 sensor location
Old Jun 18, 2007 | 04:14 AM
illini's Avatar
illini
Default O2 sensor location
I have a 94 GT 5.0 that I recently bought. The Check engine light came of and the code says bad O2 sensor. I got under the car and found that the previous owner had removed the CATS. I would like to put the converters back on, so my question is do the sensors go before or after the CATS? Hopefully putting them on and replacing the sensors will help both throttle response and gas milage. The car runs very rich.
Old Jun 18, 2007 | 04:39 AM
Blckstng93's Avatar
Blckstng93
Default RE: O2 sensor location
Get a BBK H-pipe. Itll have bungs for the o2 sensors.
Old Jun 18, 2007 | 04:51 AM
mattdel's Avatar
mattdel
fixing the bad o2 sensor will fix the problem. cats aren't going to help.
Old Jun 18, 2007 | 11:12 AM
samseed101's Avatar
samseed101
The sensors go before the cats. But as stated above, adding cats isn't going to solve your problem. Just swap out the O2 sensors for new ones. Unless the previous owner removed them and wended over the bungs. But that seems unlikely.
Joel5.0's Avatar
Joel5.0
Before the cat-cons........under the header collector.
jwog666
Dec 27, 2021 08:09 PM
mrtrodonet
Sep 19, 2020 03:12 PM
Dathan
Oct 5, 2015 05:52 AM
jc409
Convertible Tech
Sep 26, 2015 08:28 AM
TfcCDR
Sep 14, 2015 12:08 PM
