what kind of spray paint for interior trim?
Ok, so im at a point where im sick of my grey interior and i dont have the money to buy black or tan trim on ebay to replace it. What kind of spray paint is made to be used oncar trim parts to keep them looking oem and not glossy or get sticky when you rest your arm on them? I plan on going with a black/tan scheme.
RE: what kind of spray paint for interior trim?
vinyl dye is your best bet. it is very easy to use, easier than spray paint since it doesnt clump up and run. you will need several coats to convert the color but it is worth it. i redid my gray interior to the same gray but its really clean without any of the old blemishes
https://mustangforums.com/m_3373208/tm.htm post 19
Scroll down to post number 19 that's the paint I used for my stang interior.
You can also look at post number 3 to see what it looked like when I was finished with it.
My door panels were red before I painted them gray.
do not and i repeat do not use dye. you will hate it and it looks like shyte! use the duplicolor interior vinyl paint. it works so awesome, i also recomend adhesion premotor as well since it will enhance the chemical bond. i used it on mine on it looks factor. no shine or anything. turned out better than i dreamed. you would have to sand this stuff off thats how well it works
treesloth
09-28-2015 07:03 AM
