94 gt valvecover ?
94 gt valvecover ?
im putting on my twisted wedge heads on the 94 5.0l. will the trickflow valve covers fit under my stock intake without any modification? if it does need modifications please let me know were at
RE: 94 gt valvecover ?
if it does need modifications it will need a spacer. then you won't be able to use then the stock strut bar and then you have to worry about the intake hitting the hood.
i had the stock valve covers with the trickflow track heat and a 3/8 spacer and it just barely barely cleared
ORIGINAL: jthorn9
Yea, if you want your sway bar, you're gonna have to go aftermarket and get one that's made to clear aftermarket intakes, such as BBK and MAC.
get rid of the strit tower brace and install a 4 point one underneath, get the 3/8 spacer and use some rtv instead of gaskets... it will work, just got to put some thought into it.
