PCV Screen?
Old Jun 23, 2007 | 10:38 AM
REDS 5.0's Avatar
REDS 5.0
Default PCV Screen?
I just pulled the original screen out from under the PCV valve(145,000 miles), does it really need one or can this be left out? My guess is I would get more oil sucked through without it and do not really want that, correct? Thanks guys................
Old Jun 23, 2007 | 10:41 AM
5.0stanger's Avatar
5.0stanger
Default RE: PCV Screen?
I would clean out your old on and put it back in....it need to be there to help keep the oil out of the intake.
Old Jun 23, 2007 | 11:49 AM
Joel5.0's Avatar
Joel5.0
Don't clean it.....replace it....its function is to strain oil from the fumes.
Old Jun 23, 2007 | 11:59 AM
REDS 5.0's Avatar
REDS 5.0
I'm gonna replace it, its only a few bucks and she deserves it. Got to replace a couple of hoses as well. Q,with it being as gunked up as it is, would this hurt my performance, milage or idle qualities. My idle is good with the exception of a little roughness. This may be caused by the cracks in some hoses, hence the reason I'm trying to go through a few things. She is stock with the exception of no cats and no air pump. My milage is around 21 MPG.
Old Jun 23, 2007 | 02:31 PM
decipha's Avatar
decipha
yep that screen could do it, if you have a slight bog when going WOT from a roll, good chance it could be that screen, i replaced mine and i swear shes a completely new wilderbeast, mine was clogged some aweful though
Old Jun 23, 2007 | 04:15 PM
REDS 5.0's Avatar
REDS 5.0
I replaced it and cleaned the PCV. Replaced a couple of lines and correctly capped a few others and she idles better and I do feel a little more pep in her giddyup. Monday she is going to the shop for a little A/C work andI wanted her to be in tip top shape.
Old Jun 23, 2007 | 04:21 PM
mattdel's Avatar
mattdel
where did you buy the new screen? i've called all my local parts stores, they dont know what i'm talking about.
Old Jun 23, 2007 | 04:24 PM
Blckstng93's Avatar
Blckstng93
I simply cleaned my filter out with some shots of carb cleaner. The filter can be taken apart if you like. Goes back together no problem.
You dont need a new screen. Clean it, let it drain for a few minutes or bump it a few times to remove excess cleaner, good as new. Very easy.
Old Jun 23, 2007 | 04:30 PM
primetime5.0's Avatar
primetime5.0
I got a screen from ford, however the stock screen wouldnt fit into my edelbrock intake
Old Jun 23, 2007 | 04:32 PM
REDS 5.0's Avatar
REDS 5.0
ORIGINAL: mattdel
As Blckstng said you can clean it, but as mine has 145,000 miles I think a new onewas a better idea. Although it is just metal screening that can be cleaned, whats a couple ofbucks. If you have an Advance Auto nearbythe part # is B15231. Its a PCVscreen.
lmurf60
Sep 24, 2015 10:07 PM
Ipaman
Sep 22, 2015 07:01 AM
yourmom6990
Sep 14, 2015 10:52 PM
Scottyboy187
SVT Forums
Sep 13, 2015 10:23 PM
Boostaddict
Lethal Performance
Sep 8, 2015 09:56 PM
