engine computer mods
Old Jun 23, 2007 | 10:36 PM
CaNaDa  Stang's Avatar
CaNaDa Stang
Default engine computer mods
I am going machine my 5.0 to a 306 and put new performance heads, exhaust, throttle body, intake on my 94 GT 5.0L. My question is will my engine computer allow the extra horsepower or will i have to get an new one/ reprogram the old one, any feed back would be great
Old Jun 23, 2007 | 10:43 PM
945LSTANG's Avatar
945LSTANG
Default RE: engine computer mods
ORIGINAL: CaNaDa Stang
you will probably need a tune. why not go for a 347 instead?? it will be quicker.
Old Jun 23, 2007 | 11:51 PM
luckythirteen13's Avatar
luckythirteen13
with those mods you dont have to get a tune but the car will run better and make more hp if you did
Old Jun 24, 2007 | 12:13 AM
CaNaDa Stang
yeah i thought stroking it to a 347 but i heard they are real unreliable when you do that and thanx for the input
Old Jun 24, 2007 | 12:19 AM
luckythirteen13
they arent any less reliable then any other motor. the problem is that they make a lot of torque and the stock block is a POS
Old Jun 25, 2007 | 05:29 AM
CaNaDa Stang
how many/what modifications would i have to do if i turned it into a 331 in order to make it last
Old Jun 25, 2007 | 11:56 AM
luckythirteen13
youd have to have the block cleaned, bored 30 over and honed. i would recomend line honing and polising the crank. you will need to buy a new crank, rods, pistons and rings. depending on the rods you use you may need to notch the block. a better oil pump would be nice and a cam that will let your motor breath. not to mention a good set of heads and an intake for max hp.
Old Jun 25, 2007 | 11:16 PM
CaNaDa Stang
hmm sounds like a lot but im sure its worth it...got to check out the local machine shop and see what it would cost to do that
Old Jun 25, 2007 | 11:19 PM
CantStopTheFox...'s Avatar
CantStopTheFox...
Its not the machine shop that is going to cost you.......it is the parts....pistons, rings, rods, etc....
Machine shops are normally pretty reasonable.
panic
Aug 28, 2015 02:37 AM
inyadreems
Aug 21, 2015 09:10 AM
Jacob4589
Aug 8, 2015 11:00 AM
