Speedometer problem
Old Jun 24, 2007 | 06:00 PM
nyfreakinrican7's Avatar
nyfreakinrican7
Default Speedometer problem
When I first got my car the speedometer cable melted to the exhaust and stopped working. I replaced the cable and now sometimes the speedometer works and other times it stays at 0 no movement at all. The cable is not kinked at all and has been routed away from the exhaust enought to where it is not being melted again. I really need this to work because I have been pulled over in my town for going 48 in a 45 in my taxi never mind in my Mustang. J.P.D would have a ball!
Old Jun 24, 2007 | 06:04 PM
raven_ghostwolf's Avatar
raven_ghostwolf
Default RE: Speedometer problem
sounds like the speedometer gear may have been stripped. Take your cable lose form the tranny and pull the gear out if the teeth look messed up at all, replace it. First thing I would do.
Old Jun 25, 2007 | 12:00 PM
nyfreakinrican7
I just put the tranny in last Monday and I don't recall the teeth being damaged on the gear. But I did notice after posting yesterday when the car is driving without the speedometer working the odometer is still accumatating mileage. Doesn't the odometer go off of the speedometer cables input?
Old Jun 25, 2007 | 02:26 PM
dukeme's Avatar
dukeme
It happened to me and it will most likely look like ths?
[align=left] [/align]
Old Jun 25, 2007 | 05:31 PM
raven_ghostwolf
yes the odometer runs off the cable if it is working ok then there is something else wrong could be the speedometer has died.
Old Jun 25, 2007 | 06:54 PM
7upedition's Avatar
7upedition
its the odometer is working and the speedo dial is not then you have a dead speedo unit... junkyard my friend, good luck
Old Jun 25, 2007 | 07:53 PM
dukeme's Avatar
dukeme
ABSOLUTELY! +!
articman
Jun 21, 2018 11:45 PM
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
