Super Charger yes or no?
RE: Super Charger yes or no?
Pro...YOU ARE THE MAN! I am going with that exact set up! Now, as far as a good vendor? How would you recommend? By the way like a dumb A** I had 3/4 of a tank when I dropped....A real balancing act to get it back up.
Damn, there was just a thread in here the other day a guy asking the same thing about where to buy a Procharger. I did a google search and posted a few links. Have to see if I can find it.
ORIGINAL: PRO50SC
At the very least 42#ers. You'll need an external pump to run with the 190 you just installed. (I run a 255 intank along w/ the external the kit came with) W/ the built motor, you will def see 500rwhp easily w/ a good tune. My procharger has performed very well. Been very happy w/ it. You won't need but 10-12 #'s of boost to attain those #'s either. Go for it and G/L!
On a side note, there is no such thing as TOO FAST!!!
Thanks PRO...Now I will do my research. I will keep you posted as to my progress. On another note, I made 2 passes in the 1/4 and with the current set up 13.66 and a 13.58 I started with 14 PSI in the backs "Tires moved up to 18 PSI. My, second launch was a bit dumpy Next time it will be with some power adder of some sort.
Actually, I'm going to say the same thing he did. I absolutely love my procharger and I wouldn't take any other supercharger over it. But if I were back to a stock engine, I'd follow r.barn's suggestion and go with a nice turbo setup.
M3hunter
09-05-2015 03:42 PM
