Lifting the tires
RE: Lifting the tires
well lifting the tires is kool and all but the point is to go forward not up.....
as for your question though, from what i have heard, weight reduction, good weight transfer, increase better suspension, nice sticky tires and disconnect the front sway bar a stock 5.0 should be able to do it or come close. but thats not what i would try for. (lifting tires)
Youll need more than just a few horses. You need better control arms, bushings, the right springs, and weight transfer as mentioned (no sway bar, battery in the trunk for example). Slicks. More torque. And practice.
Sub connectors help to.
i dont think you need that much ponies.....there is someone on this forum that can do it and he hardly has any mods to his motor. we've had this conversation before, you can almost do it stock
