Little Horse Power
Little Horse Power
I purchased a 1994 Mustang GT and everything looks like it is running correctly. Hooked the engine up to the diagnostics machine at the dealership and everything looks to be running in normal paramaters. However, the stock car has vary little horse power. Any suggestions as to where I should focus my effort if the engine is fine? Thank you.
Little Horse Power
I just posted this for someone else, read the 2nd post in the thread:</P>
https://mustangforums.com/forum_post...=3406&PN=1</P>
Little Horse Power
By "little horsepower", I mean something is wrong other than the engine. Typically, if you throttle a 5.0, it should peal out down the road. I think I have a V6 van that feels like it has more horsepower than my V8. Any suggestions?
Little Horse Power
here is a few free things to check</P>
1. check fuel pressure</P>
2. check air filter</P>
3. tune up when was the last one</P>
4. plug wires</P>
5. fuel filter</P>
6. pcv </P>
7. stopped up cats...is it running hot or eating gas</P>
8. check timing</P>
9. vacuum leak</P>
10. well 9 is enough to start with<IMG src=smileys/smiley4.gif border="0"></P>
Little Horse Power
OK I have checked the following.</P>
Originally Posted by vfast
</P>
1. check fuel pressure - CHECKED</P>
2. check air filter - CHECKED</P>
3. tune up when was the last one - JUST DONE</P>
4. plug wires - NEW</P>
5. fuel filter - CHANGED</P>
6. pcv - CHANGED</P>
7. stopped up cats...is it running hot or eating gas - I DON't BELIEVE IT IS THIS</P>
8. check timing - WORKING ON CHECKING</P>
9. vacuum leak - NO VACUUM LEAKS</P>
Little Horse Power
Check for leaky or clogged fuel injectors.
If you've got the oem cats it's entirely possible that they've gone bad.
When was the last time you replaced the O2 sensors?
Last time you cleaned the K&N?
