cold air intakes
cold air intakes
What brand of cold air intakes do you prefer?Where do you get the best deal?Is it better to get the one that bolts to the fenderwell?
I've seen the ones that don't bolt up to the fenderwell.
Can someone post a picture of one that bolts up to the fenderwell?
I'm hoping to be buying a 91 coupe.It's stock except for a flowmaster exhaust.I plan on later installing an E-cam but what
bolt-onmods would benefit a stock engine?I want to keep this a daily driver but I want it to run good too.
RE: cold air intakes
www.shopcoldairkits.com
i just seen this on powerblock tv. you should check it out, looks like they have a lot of different makes and modles of CAI.
ORIGINAL: Dallas
ORIGINAL: 89regattaLX
on ebay they can be had for $50...cold air is cold air, doesn't matter what brand...go with the fenderwell mount
The ones on ebay DO work perfectely fine. your getting ripped off when you buy a 130+ dollar set-up. "cold air" intakes dont really cool done the air temp enough to make a difference. Your getting the performance out of the straightened air flow. When you smooth out the air flow, the more velocity you have and the quicker the air will enter the engine. Brands dont mean ****.
